Re: 3 point hitch for a b
steve
12-09-2002 15:07:15
My old "C" had a belly mower and therefore there was a 4 inch channel section bolted between the finald drive housings were the U drawbar normally goes. THe channel supported a couple pulleys, etc. I welded two additional brackets onto this channel to attache the two lower pulling arms of the 3 point. Went to Farm King and bought two arms for 8N ford for $50. each with the swivel end sockets. I then made a straight shaft with bushing mount on each end, and two upper lift arms, all home made, and mounded it to the tractor seat frame rails, on the fender rear bolts. Two arms point straight backeward, and one downward. Mounted a CA cylinder on the 4 inch chanel below that pushed on the upper arm to "rock" the upper shaft. VEry heavy duty outfit. You can also look at an aftermarket unit thru several of the guys on this page. These are o.k., but $300-$450. I figure i built one for under $200. Look at the worksaver home page for some good pictures and prices.
