Re: Tractor split/Help!
david
12-07-2002 16:16:01
if you can get to within 1/2 inch,isnt the only thing stopping you is the pilot bearing,if used.As long as you have it apart slide the pilot bearing up on the input shaft to be sure. I've at times,tapered the end of the shaft just a little.Also I've bumped the starter to rock it enough to help it slip in. Be sure its not in gear.
