Re: Log splitter on WD
JMS/MN
12-02-2002 19:44:37
I think you might be limited by the hydraulic capacity of the WD, although by adding a resevoir, that could be handled. Be aware that the AC system is very high pressure, so the cylinder would have to take over 3000 psi, unless you install a lower pressure-relief valve in the system, and then you are left with low volume. A return oil line can be plumbed into the existing system. I think your best bet for a satisfactory system is to use a separate pto powered pump. Or even a separate engine and pump setup- Might take less fuel, offset by the higher cost of equipment.
