Re: D17 governor weights
Duey (IA)
11-30-2002 07:35:06
Eldon,
I think the front, small cover exposes the gov spring. I don't think you could see enough to determine any wear. If you mark where the rotor is for reinstall,I think the whole assembly can be taken out. Now if you are talking about the front timing cover, the gov would be exposed??? Duey
Eldon
11-30-2002 08:11:14
 Re: Re: D17 governor weights in reply to Duey (IA), 11-30-2002 07:35:06
Thanks Duey, I meant the small cover....seems someone has had it off before as the gasket is silicon. I was just hoping it was a simple way to check for wear. I guess I'd better pull the whole thing off.
