Re: Tight B Sleeves
Michael Draper
11-29-2002 17:32:13
AS an alternative to all that grinding. You can let the sleeves set in a freezer overnight. The sleeve gets cold and shrinks just enough to fit - You can't spend a lot of time fooling around though as the sleeves return to normal size as they warm back up. The permatex sealer is a great idea. It also works well on a milled head and block with a thin(24 guage or less)metal gasket as a slight compression booster. But this can be risky, and MURPHY usually wins in the end -usually only pullers go to that much trouble for such slight gains.
