Re: Tight B Sleeves
Ron
11-26-2002 18:55:05
After the sleeves are in ( or, use this on the "O" rings, too) pour a coating of Permatex aviation sealer into the bottom of the block, to make sure the "O" rings Never leak..!!! About a pint should do it... Works wonders on clean WD-45 blocks, too...!! The front side of the front sleeve always runs colder than the rest of the sleeves, too-that is why the front cylinder of an in-line engine always wears toward the FRONT... I would coat part of the front side of the front sleeve ( about 1/4 of it ) to even out the heat...
