Re: B is backfiring after sitting three years, what may be the cause?
Dennis Benson
11-26-2002 16:47:54
If I remember right, the cumbustion chamber is deep enough so that the pistons won't hit the valves and bend them. But, like the others said, the valves are probably rusted into the guides, which would bend a push rod. Also, if it rusted as much as it sounds like it rusted, then it was rusting on the crankshaft journals, and in the oil passageways. That rust will be grinding aeway at the bearings real fast. It might be a good idea to plan on dismantling the engine and cleaning out the dirt and rust. When I was learning about engines I learned that one on a IH 101 combine, it threw out the rods.
