Re: HOW SNAP COUPLER WORKS?
JMS/MN
11-26-2002 16:45:13
When attaching snap-coupler implements, or the old pin drawbar type, for that matter- attach the drawbar first, then the lift arms. The large spring under the tractor is part of the load-sensing and draft control system (Traction Booster). That's why there is a mechanical connection between the spring and the hydraulic pump. There is very little movement of the spring when it actuates the traction booster system. By the way- Snap-Coupler refers to the bell-shaped housing that the drawbar or pull bar of the implement attaches to- not the lift arms or latches.
