HOW SNAP COUPLER WORKS?
Tom Z
11-23-2002 11:03:09
JUST GOT 1ST WD, HAS LARGE SPRING LOOKING PART UNDER HYDRAULICS, BY THE PTO SHAFT THAT DRAWBAR ATTACHS TO. DOES THIS MOVE IN AND OUT AND WHAT IS THE LEVER THAT IS ATTACHED TO THE HYDRAULIC PUMP DO. CAN SOMEONE TELL ME THE PROPER WAY TO ATTACH A REAR BLADE (SNAP COUPLER ARMS FIRST OR DRAWBAR YOKE FIRST?). ANY HELP WOULD BE APPRECIATED. FIRST ALLIS AND CONFUSED!
JMS/MN
11-26-2002 16:45:13
 Re: HOW SNAP COUPLER WORKS? in reply to Tom Z, 11-23-2002 11:03:09
When attaching snap-coupler implements, or the old pin drawbar type, for that matter- attach the drawbar first, then the lift arms. The large spring under the tractor is part of the load-sensing and draft control system (Traction Booster). That's why there is a mechanical connection between the spring and the hydraulic pump. There is very little movement of the spring when it actuates the traction booster system. By the way- Snap-Coupler refers to the bell-shaped housing that the drawbar or pull bar of the implement attaches to- not the lift arms or latches.
