Re: Locating farm field tile
Farmer Tom
11-14-2002 09:12:49
Most of my field tile runs show up on the surface as holes or wet spots - easily found by a tractor, implement or wagon tire.
Duey (IA)
11-15-2002 05:11:34
 Re: Re: Locating farm field tile in reply to Farmer Tom, 11-14-2002 09:12:49
Farmer Tom, It sounds like the outlet for your tile runs is not big enough or you have a lot of water coming at you from upstream. Water coming up out of the tile from upstream pressure, will wash out holes and a wet spot would indicate a restriction, or broken tile or not enough fall to the outlet???
Farmer Tom
11-15-2002 05:43:02
 Re: Re: Re: Locating farm field tile in reply to Duey (IA), 11-15-2002 05:11:34
Your right on all points. My bigest problem with the tile is that most of the it is old (early 1900's)and is simply falling apart and crushes. So, I just fix the bad spots as they develop. Re-tiling is just out of my budget right now, but that is the real answer to the problem. Thanks.
