Re: Brake replacementon B
Justin Ny
11-05-2002 19:14:07
Glenn, John is correct,gain acess to your band(top),Remove linkage ect...The pins can really Bite!!!!! !!Normally spray the pins with penetrating oil for a couple days.Find something hard that you can get in on the pin and find a big hammer you do want to be careful though,drive the pin from the torque tube side toward the tire,you will need to get a smaller pin to drive with after you get the pin to move alittle it is a akward angle.It is not really that hard just time consuming,I don't remove tires unless I have a really hard time with the pins,hope this helps,Good Luck! Justin NY
