Company Logo (800) 853-2651 Shop Now
Re: starting a B, hand crank resistance?
John W.
10-27-2002 17:03:19
Aaron; First,crank starting any engine can be hazardous if not done properly. Turn engine SLOWLY until compression begins to build. Then re-engage the crank with handle at bottom. Pull crank up to top. DO NOT try to rotate crank in a full circle. If the engine kicks back as you're going over the top you could be seriosly injured if hit by crank. Engines that have been setting for a long time tend to be stiff. Baby it for a while as you would a rebuild. It should start fairly easy IF the fuel mixture is right and the timing correct. But, as I said it may be stiff for a while, and a bit tough to start, remenber, half turns on the crank, kick backs hurt,after you wake up that is.
Diesel Don
10-28-2002 20:04:16
 Re: Re: starting a B, hand crank resistance? in reply to John W., 10-27-2002 17:03:19
One more thing-DO NOT wrap your thumb around the crank.That way if it does kick back,the crank will slip out of your hand.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
