Re: WC manifold change
Butch (OH)
10-26-2002 19:52:49
New manifold, or another manifold? Believe Tom is right on this one. Take it back off, but before you apply gook in an attemp to fix it check it with a sraight edge, and check the head too but not too many problems with the head, usualy the manifold is warped. Doesn't cost much to have the manifold milled or sanded flat. Once you get things flat forget the gook and bolt it back on with good gaskets. The manifold grows quicker and more than the head does when the temps are coming up. That's why Allis used the metal rings with gasket between the ring and manifold only, so the rings could slide on the head and remain sealed.
