Re: CIG BUTT IN CYLINDER HEAD
Don LC
10-22-2002 09:08:59
Take all the plugs out....the engine will turn easier....put the tractor in nutral.....slowly turn the engine bachwards....(you could put it in high gear and have someone rock the tractor backwards,with the rear wheel while you watch at the hole with a pair of needle nose pliers)since the piston was on the intake stroke maybe the piston is not at the bottom yet..... It just might come back out the hole.....the cig. butt will burn up, when you start the engine.....
