Re: cutting hay with a B
Hyperpack
10-12-2002 21:16:24
Sid is right the mounted mower is great,The official name is "BC mower"
I have a 39 B with this mower it works excellent is well balanced has plenty of power and easy to run.My Grandpa put a 7 foot bar on his B and cut 100 acres for over 30 years, If the mower is set up right you can run in second gear in heavy grass hay with no problems.Here in northern Wi. these mowers are fairly easy to find, They are easy to mount and dont take up much room in the shed when not mounted.
It would be hard to beat this combination.
