Re: Allis CA 3- point conversion
Eldon
10-12-2002 19:51:48
You can make a fairly good conversion by replacing the drawbar bail pins (snap coupler CA) with class I 3pt implement pins (the ones with the threaded ends). Then attach replacement arms (8N Ford?) to them with some adjustable links from the arms to the lift arms. These parts are available at our Big R (Farm & Fleet etc.) store. Arms are red ($41 ea and links are blue ($28 ea). Then you just have to fabricate a top link mount to bolt above the pto using the holes around the shaft or buy one from the guys that sell conversions. You might want to hook some crossed chains to the arms and drawbar bail to eliminate sway. Total cost should be around $175 with very little work.
DON MUELLER
10-15-2002 06:16:08
 Re: Re: Allis CA 3- point conversion in reply to Eldon, 10-12-2002 19:51:48
I PURCHASED ONE FROM DON VAN EATON ABUOT 3 YEARS AGO AND IT HAS BEEN ABSOLUTELY SUPREB ---HANDLES EVERY THING.
