Re: Best way to rig motor for removal-WD45
Tom Westerfield
10-12-2002 13:25:02
Just finished the process. I have an overhead hoist. I made a bracket out of 2 inch angle iron, long enough to span the four bolts that hold on the valve cover. I drilled holes in one face of the angle iron to match the 1st and 4th valve cover bolt. I cut notches for the other two. On the other face of the angle iron I drilled a hole 1 inch to the rear of center. The latter is to cause the engine to raise on the front a little higher than the rear. You do have to release the crank and the steering to pull the motor up but its rather quick.
