Re: Manifold gasket
Steve in N.J.
10-07-2002 16:25:57
Mike,
Most modern replacement intake gaskets usually don't need any sealant added to them. Years ago when the gasket material composition was a lot less sophisticated, a little "Indian head" shelack worked quite well. (Whew, I'm datin' myself now) Todays composition gaskets crush & seal better than the early days. Now on a head gasket, that might be a different story depending on what yer' workin' on....
Steve B.
TractorMike
10-08-2002 04:46:59
 Re: Re: Manifold gasket in reply to Steve in N.J., 10-07-2002 16:25:57
Thanks Steve. Now would you put sealant on a head gasket for a 1941 C or a 1952 B? TractorMike
Steve in N.J.
10-08-2002 06:15:21
 Re: Re: Re: Manifold gasket in reply to TractorMike, 10-08-2002 04:46:59
Mike,
I did use a "brush-on" Permatex type sealant on the deck of the block on my B (1948) because these engines have removable liners in them and I figured a little sealant couldn't hurt around the area where the liners stick up above the deck just a fuzz. These little engines really work hard under load, and I think that a little sealant in those areas would help the gasket keep a good seal at higher combustion temps in a heavy work load condition...Again, it's up to the individual. I guess I'm from the "old school"...
Steve B.
