Re: WD45 transmission and rear fluid
JMS/MN
10-06-2002 10:39:52
The OPERATOR'S manual for the WD45 calls for two separate fluids- for good reason. If the seal is out, it should be replaced. If you replace the seal so that fluids do not commingle and equalize, you will get an accurate reading at the hydraulic fill dipstick. These are not today's tractors that use a common fluid for transmission, hydraulics, and rear end. If you intend to 'save' money now, you'll pay for it down the road.
