Company Logo (800) 853-2651 Shop Now
Re: G hydrolic pump repair ? ?
Eric Egland
10-02-2002 21:37:43
Don, there isn't much available for these pumps any longer. I feel that you have to bite the bullet and remove the pump for a look-see. The parts manual is a must as well as the I-T AC manual. There may be a piece of debris under the bypass ball or the bypass spring may be missing.(You can check this without removing the pump). Get the I-T AC manual at minimum, the pump and repair routine is in there. Good Luck
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
Latest Ad: IHC McCormick Deering WD-40. WDC-516. Engine also is serial number WDC516. Vertical injector head. On rubber. Round spoke rims. Starts and runs nice. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
