Re: wd45 12v conversion
Author |
steve
10-02-2002 17:26:46
Dale, all are based on fact. Fist, the battery will discharge if you do not disconnect the #1 terminal from 12 volts when the motor is off. To do this you connect to the accessory terminal on the key, or the + terminal of the coil, or a toggle switch. Anyway to stop the flow of voltage backward from the battery thru the alternator to ground. Second, you want the alternator to charge properly. You could use a 12 volt excitation, but engine speed usually is about 2000 RPM to get the alternator to "kick in". A small resistor or light bulb or resistance wire in the circuit will cut the voltage to the excitation portion of the alternator and make it charge "better" in my opinion. I have installed a few delcos on tractors and use a 10 ohm -10 watt resistor from radio shack and the alternator will charge with the standard pulley at 500 RPM engine speed. I think this has a lot to do with it, others may argue. Car companies use a light bulb on the dash or a resistance wire in the harness to accomplish this. I got the 10 ohm resistor idea from a DELCO service test manual 20 years ago for testing on the bench. Works every time. reisitor is $1.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
A pair of 11x38 drop center rims off of an Oliver 77, super nice originals, never had fluid in them, can send pictures,calls only
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
