Re: Where is the hydraulic plug for my lil B???
steve
10-01-2002 15:53:12
the transmission, differential/bevel gear and the PTO / hydraulic housings all three share the same oil. the plug is on the left side of the transmission, in front of the axle housing. probably a 1 inch pipe plug. It takes about 7 or 8 quarts of oil. I like to use trans/hydraulic fluid (20 wt oil) that you can get from Wal Mart or the local Farm Store. There are three plugs on the bottom of the three cases. I would drain all three and start over with new oil. Get the old crud out. It only cost $10 for a 2 gallon can of new oil. Fill to the top of the plug hole.
