Re: Allis B positive ground
John W.
09-29-2002 23:53:16
Kevin; It sounds to me that a single wire delco alternator is on your tractor. I have a C set up that way. My started is the original 6 volt, The positive side cable is connected to the start switch on the starter together with the wire from the alternator, the negitive side of the battery is grounded to the frame. Lights are wired as usual with switch mounted in the amp meter box. I wondered about a 6 volt starter run on 12 volts, so I contacted Williams Electric, a rebuilder here, and was told the windings in the old starter were very heavy and easily able to handle 12 volts, as long as the starter was in good working order otherwise. Hope this helps. John W.
