Re: Sluggish Hydraulics
John W.
09-29-2002 21:30:04
Louis; Could be a couple of things. Are you absolutely sure you are using the correct type of fluid? Depending on the year, it could use Hy-trans or stright hyd. fluid. The other possibles require removing the pump. Once done, check the pump inlet for restriction, I once found part of a shop rag in the inlet of a D-14. After so long it would get sucked up by the pump a block the inlet causing the hyd. to work very slowly or not at all. Then check the pump for worn gears or worse yet, a badly worn or corroded pump housing. Good Luck. John W.
Louis Torrans
09-30-2002 17:27:35
 Re: Re: Sluggish Hydraulics in reply to John W., 09-29-2002 21:30:04
Thanks John! I'm going by the AC service manual on the oil but I'll check it through again. Your idea about pickup blockage may be a good place to look for trouble so I guess the pump is going to come off and check all that out.
Much Obliged!
Louis Torrans
