Re: Oil in the brake housing
Author |
J.W.
09-29-2002 20:42:48
Karen; The gunk in the axle extension/brake housing is more than likely an acumulation of years and years. This tends to be a negelected area on a lot of tractors mostly because its a tough spot to get to. Some of it no doubt leaked from the differential, there is a seal in the extension housing to keep oil in and dirt out. The rear wheel, final drive case, and axle extension must be disassembled in order to change this seal. No small task, and it will be nessesary to replace the gaskets between these parts as well. The final drive assembly is HEAVY and ackward to handle, so recruit some help. The seals are available thruogh National oil seals and NAPA auto parts usually has them or can order them. Cleaning the inside of the extension is done with a long handled toilet type brush soaked in diesel fuel. You may have to scrub and rinse a few times to get it clean. Hope this helps, by the way take the old seals with you, makes it easier to match, if the rubber is gone from the seal, measure the axle with calipers to get the seal inside diameter. J.W.
Karen
09-30-2002 01:16:19
Re: Re: Oil in the brake housing in reply to J.W., 09-29-2002 20:42:48
Thanks, J.W. for the tips! I've been reluctant to tear into it for fear that I couldn't find the replacement seals. The tractor belonged to my grandfather and in all the years he had it I don't think he ever did anything with the brakes, so I'm sure there is 54 years of accumulated gunk in there.
steve
09-30-2002 16:13:42
Re: Re: Re: Oil in the brake housing in reply to Karen, 09-30-2002 01:16:19
it is not uncommon to have piles of gunk and mouse nest in the brake cavity after 20-40 years. if it dont drip oil, then it probably is not a problem. it is a good idea to clean it out, oil does not help the brake shoes. if you do decide to "fix it" check what is dripping. if it looks like 20 wt oil it came from the center (differential bevel gear housing behind transmission). if it is heavy 90 wt then it came from the final drive housing (normally not). to change the bevel gear housing seal you just jack up the tractor "good" take out the 4 bolts holding the axle- brake shaft housing to the bevel gear housing and slide it away from the tractor, final drive and all. It is a big chunk, but dont have to disassemble any shafts or bearings. now the final drive outside the brake drum, thats a different story.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
A pair of 11x38 drop center rims off of an Oliver 77, super nice originals, never had fluid in them, can send pictures,calls only
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
