Re: Starter won't start B
Steve in N.J.
09-29-2002 18:58:45
Dail,
If clean grounds don't do the trick as Duey mentioned, check the battery cable to the starter motor. Corrosion can build up inside the cable where you can't see it, especially if it's a pretty old cable that's been out in the elements for a while. This kills the power to the starter when the load try's to go through it. If that cable get's hot, it could be the cable itself that's bad... Steve B.
