Re: Starter won't start B
Duey (IA)
09-29-2002 15:53:58
Dail,
Remove the starter and clean the rust from the mounting hole and paint from the starter where it mounts in the hole. Also shine up the area where the battery ground strap fastens. If that doesn,t do it, check all connections for heat being generated when trying to start the engine. A poor connection will generate heat. You may find the cable gets hot indicating it,s not a heavy enough gauge. Duey
steve
09-29-2002 17:58:22
 Re: Re: Starter won't start B in reply to Duey (IA), 09-29-2002 15:53:58
what Duey said works 90% of the time.
