Company Logo (800) 853-2651 Shop Now
Re: draw bar
CHALMERS BOB
09-27-2002 19:59:51
UNSURE ABOUT D/B LENGTH THERE IS AN SAE SPEC ON LENGTH BECAUSE OF PTO ATTACH.
TO TIME THE MAG, REMOVE #1 PLUG,PLACE YOUR THUMB OVER HOLE, CRANK UNTIL YOU FEEL AIR BEING PUSHED OUT OF PLUG HOLE. THEN LOOK IN THE INSPECTION HOLE ON SIDE OF BELL HOUSING FOR THE FIRE MARK, MIGHT HAVE TO TURN CRANK FURTHER, THEN REMOVE THE DIST CAP FROM THE MAG AND TURN THE COUPLING TO MATCH THE MATING PIECE ON THE GOVENOR SHAFT THIS SHOULD PUT THE ROTOR AT THE TIMING MARK INSIDE OF THE DIST (UPPER LEFT POSITION THERE IS AN INDICATOR TO ALIGN TO, A RAISED AREA, CORRESPONDS TO #1 WIRE POSITION. NOW IF YOUR NOT TOTALLY COFUSED IT SHOULD WORK.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Two rear tires and spin out rims. 16.9x28 on there now. Help me out. I dont mind going with a different size but stay kind of close. Please contact me asap. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
