Re: Pitman arm bearing
acd17toy
09-22-2002 19:04:58
take your old bearings out and go to your local auto or bearing store, there should be numbers on the bearings and the brand name also. with those numbers they should be able to supply you with new parts. also try the local Agco dealer. As for the housing go to the local tractor salvage yard. are you postive that the mower is a AC? other companys made semi mount mowers also.
