Re: WC Starts easy, runs, and then quits.....Starts up again easy
RayP(MI)
09-22-2002 12:58:39
Scott, I don't often post on the AC board, as I don't have one, but check from time to time. Had exactly the same problem on a Farmall 200 a while back. Once I discovered the problem, and cleaned up the inside of the tank, as best I could, (baffles), I went one step further. Removed the sediment bowl assembly. Drilled out the opening in the top to accept a length of automobile radio antenna tube. Inserted tube (force fit) into the mouth of the inlet on the sediment bowl and cut it off so the tube extended up into the tank a little bit. This makes the gas inlet to the sediment bowl half an inch or so above the bottom of the tank. That way rust dirt and flakes settle harmlessly in the bottom of the tank. One of these days, I suppose I'll have to figurew out how to suck the sediment off the tank bottom! Good luck!
