Re: WD wouldn't run right.
Mark from MN
09-20-2002 11:48:44
Had similar problem on my wd exept I found the intake gaskets sucked in but had same effect. My guess is the way the manifold is styled. The outside cylinders are farther away from the center bolts/cylinders. the center of the manifold is a much larger and heavier cast of metal and wont warp
away fromt the cylinder head as easily and the outside intake runners.
