Re: WC BLOCK CRACKS
BushogPapa
09-20-2002 06:27:43
WC & WD blocks crak at the lower 1-2 & 3-4 webs...I think because of the very narrow web, and stalling the engine--Hot...and not turning it over, to allow the heat to get away from the pistons that are stopped at the bottom of the cylinders.... Even if I run out of gas, I turn it over a few times, to even out the heat in the cylinders. Pinning the block is advisable.....Even if you don't, carefully pour a Pint of Aircraft gasket sealer into the CLEAN block, allowing it to coat all around every sleeve bottom, and web. That will prevent water and antifreeze from getting into the oil pan.... My block was Resistance Welded, and Pinned...never gave any problem before it was re-built, except a hint of moisture on the dip-stick...
