Re: 1950 WD 12v Wiring Diagram
Duey (IA)
09-12-2002 19:51:11
Tulsa TractorGuy, I think you will find what you want on my web page. Duey
Tulsa TractorGuy
09-14-2002 10:49:27
 Re: Re: 1950 WD 12v Wiring Diagram in reply to Duey (IA), 09-12-2002 19:51:11
Duey, I know this is a stupid question, but your wiring diagram does not show the cable to the starter or a selinoid (or something like a switch) that will provide the fire to the starter. Could you please tell me how that portion of the wiring diagram works. THANKS MILLIONS!!!! Dumb Tulsa TractorGuy----
Duey (IA)
09-14-2002 13:58:25
 Re: Re: Re: 1950 WD 12v Wiring Diagram in reply to Tulsa TractorGuy, 09-14-2002 10:49:27
Tulsa TractorGuy,
It's there, unless you were looking at the wrong diagram. Scroll around to find what you need. If you want to use a solenoid, you must change the connection on the starter, other wise use the same manual pull start. Duey
Tulsa TractorGuy
09-15-2002 09:14:36
 Re: Re: Re: Re: 1950 WD 12v Wiring Diagram in reply to Duey (IA), 09-14-2002 13:58:25
Duey, I am unable to get your wiring diagrams when I click on your ((6 to 12 conversion/ with selenoid)) or your ((6 to 12 conversion with manual pull start)). My machine says that your WEB site is unavailable. Can you e-mail the complete wiring diagrams directly to me? I would sure appreciate it if you would! I'm sorry to be so much trouble!!!! Tulsa TractorGuy the REAL DUMMY!!!!
Tulsa TractorGuy
09-15-2002 09:14:14
Duey (IA)
09-14-2002 14:10:48
This one shows the manual pull start wiring. The diagram does not show the pull rod to the switch, just the switch on the starter. Duey
