Re: Hydrolic lift power on a 52 WD
Author |
Dave Grubb
09-09-2002 08:48:44
If you have a remote outlet you can adapt a gage to the outlet and read the systems pressure. If you do not have a remote outlet you can plumb a gage into the plugged port on top of the hydraulic pump body just foreward of the hold valve. This is where the traction booster gage was connected. You must use a gage with a 0-4000 psi or 0-5000 psi range. The system should develope around 3500-3900 psi. A lot of times a weak system is due to broken springs on the pump pistons. The pump removal and springs replacement is fairly easy, just follow the manual.
BJ
09-09-2002 11:56:37
Re: Re: Hydrolic lift power on a 52 WD in reply to Dave Grubb, 09-09-2002 08:48:44
Dave, Thanks for the good information. Where is a good source for a gague like the one you describe? I'd like to buy one so I know exactly what it's doing. Thanks Brian
Dave Grubb
09-09-2002 13:42:20
Re: Re: Re: Hydrolic lift power on a 52 WD in reply to BJ, 09-09-2002 11:56:37
I use mcmaster.com a lot. They are reasonable and quick. You can also get a gage that will work from northern.com or northerntools.com, can't recall which address is correct. They are the old Northern Hydraulics folks.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
