Re: WD45 Drains and Fill sites?
Tom
09-08-2002 17:29:26
There are 3 drain pulgs for the transmission and clutch. Under the rear end. Under the transmission in the sheetmetal plate bolted on there. The bottom of the PTO or the plate that covers the PTO opening if you don't have a PTO. There are two fills on the left side of the tractor too. Use all drains and fills. They are interconnected but to drain it all and fill evenly, not having to wait for the oil to flow through a bearing etc, use them all. The hydraulic is the other plug, the one you mention, and the fill is the twist cap the little dipstick. Don't forget to do the final drives. You have to take the pans off and clean them. You can then fill them through the fill/level plug. Or you can nearly fill them and put them on and bolt them up. They take 90 weight gear oil.
Brian G. NY
09-09-2002 05:23:15
 Re: Re: WD45 Drains and Fill sites? in reply to Tom, 09-08-2002 17:29:26
When draining the hydraulic system, it's a good idea to drain the pump control as well. There is a small plug on the bottom of the pump control.
Tom
09-09-2002 17:11:42
 Re: Re: Re: WD45 Drains and Fill sites? in reply to Brian G. NY, 09-09-2002 05:23:15
Yes, you are right, I forgot about that one! Thanks.
