Re: wd45 trans
DanD.
08-31-2002 17:05:45
The WD (except for about the last year of production) had a different transmission. The WD had a sliding gear transmission while the newest WD's and the WD45 had a constant mesh transmission. It's easy to tell them apart. The old sliding gear tranny had a straight shifting lever while the shifting lever on the constant mesh unit was curved.
Tom
08-31-2002 19:35:21
 Re: Re: wd45 trans in reply to DanD., 08-31-2002 17:05:45
However if you were to change out the whole transmission they would interchange I think??
Carp
09-01-2002 20:40:01
 Re: Re: Re: wd45 trans in reply to Tom, 08-31-2002 19:35:21
Yep, they sure will. Just have to be careful of how the torq tubes go together. I think that they don't exactly match up at the bottom and have a seaping problem. Dad had to weld a small piece in the bottom of a WD torq tube he put in a WD 45.
smithey
09-06-2002 18:32:50
 Re: Re: Re: Re: wd45 trans in reply to Carp, 09-01-2002 20:40:01
thanks guys for the input i will take a closer look at the troq tube again thank all of you
r smithey
