Re: D-17 Utility vs. Row-Crop
JMS/MN
08-29-2002 11:35:02
As long as it has the same eight-bolt pattern and center hole diameter, it should swap ok. I'd imagine the hubs are the same casting. Is it perhaps the D17 Industrial, with the shuttle clutch instead of the power director (hi-lo) clutch? Shuttle clucth gives it forward and reverse in each gear, not hi-lo. I've often seem those without the power adjust rear wheels, also has a solid wide front, instead of the roll-shift front axle. Actually, row-crop refers to the narrow front D17, since it allows for later cultivation of row crops than the wide front version. Limiting factor is then the clearance under only the rear axle, not the front.
