Company Logo (800) 853-2651 Shop Now
Re: c
Nick
08-23-2002 16:01:08
OF COURSE! IT's AN ALLIS! The "C" is useful for anything you can run with the PTO or belt, such as sprayers and mowers, or pull at the drawbar, such as, discs, drags, mowers, planters, plows, harvesters, wagons, sprayers, and cultivators. Allis also made many implements designed for the "C" such as, the All-Crop 40 Harvester/Combine, a mounted sickle mower, mounted planters and cultivators, mounted one and 2-way plows and middlebusters, and snowplows. A bale loader designed for used with the Roto-Baler was also produced for the C. As you can see there was quite an array of used for the C. Hope this helps!
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
Latest Ad: Corn reels for JD head with hyd motor 6-30, 4-38 both very goog [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
