Re: Bolt hitting oil pan
Craig MO
08-22-2002 20:18:08
This is a special bolt that has a larger shank and smaller threads. It goes in from the front to the back with the nut facing away from the pan. The A frame should tighten up tight to the plate that is there on the back of engine mount. They have a tendancy to wear plate, bolt and A frame which lets it cock up a get into pan. I have bored out pieces and put in steel bushings with a new pin when this has happened in the past.
