Re: AC CA Wide Front? Is It True?
steve
08-22-2002 19:37:04
if you look at a B you will see the steerning box arm points straight down and the steering rod to the front end goes to the left wheel king pin area. On the C, it was originally designed as a tricycle front end, so the front steering arm is below the radiator on the pivot for the tricycle wheel. When yo uput a wide front end, you still have the steering arm under the radiator and the steering box arm points striaght up. I think the CA is the same?
