Re: WD-45 box blade troubles
Eldon (WA)
08-22-2002 08:02:46
Do you have an anti-sway device on the lift arms such as chains? If the implement can move from side to side the top link will try to move with it. I saw an easy set-up where crossed chains were used (the rear of the arm on one side is connected to the front of the other arm). You could also try putting hose clamps on either side of the clevis (maybe a piece of rubber hose under them).
Craig
08-22-2002 08:33:52
 Re: Re: WD-45 box blade troubles in reply to Eldon (WA), 08-22-2002 08:02:46
I had the same trouble, I tried the chains and it was more trouble than the effort so I switched to using a set of big cable clamps on each side of the clevis cleared up the problem, as for lifting the rear of the box, youll probably want to add some weight to the back of it I used 4 100lb IH style front weights and had to reduce the number of teeth in the ground to four instead of seven
for traction purposes
