Re: engine sleeves
Butch (OH)
08-14-2002 06:46:02
I am a little comfused by your post so if I answer a qestion you didn't ask, my appologies. The engine is wet sleeved, the dimensions of which are the same for WC,WD, and WD-45. All share a 4" bore. The commen overbore kit is 4.125 and the OD is the same, you just slide them in like the original 4 inchers. I am reasonably sure that you can't go 4.250 without increasing the OD of the sleeve and performing the block boring work you discribed. If you go with a STD 4.125 overbore kit make sure you get it for the correct stroke WC-WD (4") or Wd-45,D-17, 170 (4.5"), the pin hieghts are different for the different strokes. The 170 kit will give at little higher compression ratio IF it is listed seperately. Some suppliers sell the WD-45 thru 170 kits under the same part number.
