Re: D17 loader retrofit
JMS/MN
08-10-2002 17:32:01
Check if your front pulley has tapped holes in it- you can mount an adapter there and a front mount pump in front of the steering casting- check with AC/AGCO or salvage yards for the setup. The pump drive shaft goes through where you put the crank for hand cranking.
