Re: HYDRAULIC MOTOR
Carl (Ohio)
08-10-2002 11:49:16
I think you will have a hard time using a hyd motor off your WD-45 unless it has a seperate hdy pump the hyd system on those are 4000 psi with low volume Id pto power or use a engine like it already has just my $.027000 Carl
oly
08-10-2002 21:28:09
 Re: Re: HYDRAULIC MOTOR in reply to Carl (Ohio), 08-10-2002 11:49:16
I have to agree the hyd system on the wd45 (we have one)will not run a motor, as you say not enough flow. Maybe the little air cooled motor isn't so bad, other that it runs fast and makes a lot of noise. Did you think about a pto application, maybe that would work, plenty of hp. good luck Oly
