Company Logo (800) 853-2651 Shop Now
Re: allis c surging
Duke(WNY)
08-09-2002 03:33:44
Here's a post I copied some time ago that you might want to check out:
Last week I was talking with the guy I bought the 1950 B from He asked if the Ventura was loose - why yes, it is. He then told me that if it's loose it will actually rotate around in the carb while the engine's running and do all sorts of weird things. The fix - take the carb apart, remove the gasket and set the two halves of the carb back together. If the body and top fit flush then the ventura is too loose. Make a *thin* washer and fit it around the Ventura so there's a small crack between the body and top of the carb when it's put together without the gasket. When I got home I checked and sure 'nuff, the carb body and top fit together flush without the gasket in place. So, I got a piece of 18 gauge aluminum electric fence wire, made a circle, and beat it flat with a hammer - probably 0.010 or maybe 0.015 inches thick (a guess on my part). I fit this washer around the Ventura just above the 4 flanges on the bottom so the washer would be between the Ventura flanges and the top part of the carb when the Ventura was installed. I put it back together and the difference was astonishing. Now it idles down to 1050 rpm with an occasional miss and I'm sure I can get it down further with a little adjustment (my 1950 will idle smoothly down to 750 rpm without a miss - it's sweet!). The tractor even runs better at load, and the governor works like it's supposed to (before when the governor cracked open it was liable to "flood out" immediately if I wasn't careful).
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 706 gas fuel tank&radiator [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
