Re: WD Hydraulics
DAve K
08-05-2002 09:08:37
This is a high pressure low volume system. You will probably run out of volume if you have much movement on external rams. I have seen set-ups where folks have drilled and tapped the top of the fluid sump and mounted an additional tank on top to increase the volume of oil available.
Dave
