Re: LOW OIL PRESSURE ON MODEL C
JOHN CAMPBELL
08-02-2002 18:27:56
I DID NOT REPLACE THE CAM BEARINGS AND THE TUBE IS STIL IN THE OIL FILTER HOUSING THIS ENGINE WOULD HOLD 12 PSI O/P BEFORE O/H HOT 9PSI IS THE BEST IT HAS KNOW WIDE OPEN COLD VERY LITTLE AT IDLE TOOK A SHIM OUT OF EACH MAIN I WILL TRY TO GET IT TOGETHER TOMOROW MORNING TOO HOT TO WORK ON IT TONIGHT THANKS JOHN
Doug in OR
08-05-2002 15:43:07
 Re: Re: LOW OIL PRESSURE ON MODEL C in reply to JOHN CAMPBELL, 08-02-2002 18:27:56
I wouldn't experiment with shims in the main bearings. The same goes for your rod bearings. Get some plasti-gauge and shim the bearings for the proper clearance - probably around .002 - leave those alone once you get the proper clearance. Otherwise, check those items the others have recommended.
