Re: 1952 CA
Author |
Al
07-31-2002 20:06:03
Not a lot of helpful information has been given. Water could have gotten into the air cleaner and on intake strokes pulled into carb, pull off air cleaner oil cup and continue troube shooting.Need to isolate problem to fuel, mechinical failure or electricial. 1) try starting fluid to see if engine will start, if it does you could have dirt or water in fuel system and needs removed. 2)check compression if all cylinder check 75-90 lbs mechanical system should be ok but you might want to remove valve cover and make sure all push rod are in place and all valves are opening and closing. 3) you say the electrical system is firing, is the system battery ignition or magneto? Are all caps dry and without cracks? Are you sure you have spark remember the firing order is 1-2-4-3. Are you the first person to work on it after it quit, maybe someone has removed the magneto and it may be out of time.
Austin
08-01-2002 08:14:05
Re: Re: 1952 CA in reply to Al, 07-31-2002 20:06:03
It is a battery ignition, all the caps are dry without cracks, and im the first one to work on it. I am getting spark to all the plugs, i will try starting fluid and if that doesnt work i will drain the fuel, he said that fuel should be fresh but i dont no after settin in the woods for months. Thanks for your help. Austin
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS
... [Read Article]
Latest Ad:
JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
