Re: WD45 Generator?
steve
07-30-2002 14:55:33
the "F" terminal is grounded thru the light switch. if the swithc is bad, or not grounded properly the charge will not work.
to test generator, ground the "F" terminal. Run the "A" straight to the ampmeter (bypass the cutout) start and see if you get 10 amps on the ampmeter and 6.5 volts (about). if not , then the generator is the problem.
