Re: WD45 frozen block and coolant in oil pan
Farmer Gene (WI
07-29-2002 06:48:58
My guess would be that the O rings on the sleeves are leaking, you could verify it by dropping the oil pan and pouring coolant in the radiator and watching where it is leaking. If you were going to replace the rings and bearings anyway it would be best to go ahead and put new sleeves in.
Jon
07-29-2002 15:51:08
 Re: Re: WD45 frozen block and coolant in oil pan in reply to Farmer Gene (WI), 07-29-2002 06:48:58
Thank you Farmer Gene. That is something I never would have thought of, and a good way to check it too. I'll try that next. Jon
